the had to have been living together for a year before they put the visa application in.... otherwise they in the shit.
(source: me and the wife)
what proof do you need?
and what if his partner is on a student visa?
bills and shit. stuff from both of you dated with the postal address you live at. stat decs from witnesses.
not sure about student visa dude. i did mine from working holiday visa...
i'd find it very bizarre if they let someone on a student visa (who has dropped out) to become engaged to someone else with a student visa and let them stay. and both people are from different countries of origin
Abbott needs to drop the Immigration hammer on this one.
might be an idea to drop a line to immigration.
+1 as I also got my partner imported on a defacto visa
If you are on a student visa and don't complete it/arent around you don't have the ability to stay. Being married here isn't enough unless you marry an Aus permament resident and can prove that it isn't suspicious
exactamundo...........
my wife is an aussie itizen. both my parents are aussie citizens. im bloody english and can speak bloody english and they are investigating the shit out of us!
Sounds like a winner, thanks Greg and Paul.
Restored my faith in the Immigration department. I'll try not to give my housemates a hard time and make sure I have their bond ready in case its short notice. its unfortunate for them, but will be glad if he goes.
let me know how it goes mate.
needs to be more people like you who report this shit.
then actual real cases like mine might not be scrutinised so much.
Strange, never had that issue on my end. Had girlfriend come on work and travel visa and live with me for 1yr. Went overseas to NZ for a week and came back for 3mth of tourist visa then applied.
Didnt even need to get married, defacto is enough.
Not sure why so much drama about gay marriage in australia. Seems to be good enough for the aus immigration department to just establish a relationship. We provided a ton of photos and proof and I dont think it was even doubted/disputed.
I imagine it depends a lot on where you're from and what Circumstances are. My gf is from Germany so I doubt they think its insincere. Wouldnt have thought coming from England would raise any red flags though.
On our visits to the consulate to file papers and so on I noticed a LOT of people were indian/se asian/african in origin. Wondered offhand if that affects things. Probably does, even if unintentionally.
guess ill have to drive one sometime to see what the fuss is. factory recaros sounds nice, probably still factory heavy though.
Guy i know through work has a modified one in Tassie.... always been tempted to buy it at Tassie price, drive for a bit then sell for profit here. who says JDM styling is a bad thing :P
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
