Vic Wasteland Thread
R31Nismoid
Nah I love how stock my engine looks and what the car can do considering that. Twas my goal to make it as quick and stock looking as possible. Ex gates and big turbos ruin that.
/knoxresident
Yeah just over 250 on 98
Not a bad hike at all for the money. I wouldn't want much more power; would struggle to put it down. Just took her for a decent spin and faaaaark does she spool up quickly. Boost gauge goes up like a tacho revving in neutral.
I don't care how much more frequently I'll be stopping there, there's something very satisfying about paying $75 for a tank of petrol!
/ethanolpreacher
272rwkw @ 16psi on United 85
RacePace "high flow" cat gave me another 10rwkw. So yeah, top end a little disappointing...prolly the small turbo maxing out...along with internal wastegate and a myriad of other "stock" looking restrictions...but the low and mid range are significantly better. I have near stock response with about 130rwkw more than stock. Car sounds beast and the exhaust smell is <3
Happy camper. Will upload graph when I get home :)
dat dere cheeky skate sesh down boronia :P annoying light wet layer hehe
also 270+ is where 33 GTST'S come alive
come at me brahs
been thinking about E85 lately with all the Scotty propaganda going around... only one other pulsar I know on E85 and it hasnt driven the same since (in a neg way, but could come down to tune). only thing that major puts me off is having to carry jerry cans around, i hate doing that.
Why do you need to carry jerry cans? Unless going long distance there are plenty of United servos around Melbourne. I have 4 within 15 mins drive of me :)
Pat do E85 or buy a modified RB25 lol
will suss out e85 supplies in Perth and then get in touch with mr. trent.
Although that means I need larger injectors (currently 555cc's) & fuel pump (currently gtr pump)....
oh nice to know.
Looks like 25kw gain all across the rev range?
Congrats on the power gain.
Looks like ~35kw in some areas.
Pretty good and that's a conservative E85 gain, really, from what I've seen. Second to NOS and boost controllers, best dollar/kw upgrade!
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
    • So I checked this out in the weekend.. and look at this. I remember watching the videos. Finally got to see it in person! BRB. Tissues. Got tonnes of other pics and videos too.      IMG_0171.mov IMG_0113.mov
    • For anyone who might be put off by the slightly wacky wheel offset shown on the box photo above, the production models are not like that. Here's some more pics of the actual product (as well as the interior)
