Shut up Leigh, let's take this to the strip!
Or are you CHICKEN?
haha, was considering taking my car to DECA for some lols if I did not sure if I'd go stockies or NT05s! aka smoke or times
Take both?
I made it through 3 DECA's and a heathcote day on a set of NT05's so as long as you don't rip it on the basketball court you should be fine.
haha yeh if I do I'll just take 2 spare stockies to rip up at the end probably
kinda want to get a catback as well! but my brain is saying don't do it because of the cop harassment
how do i kill my auto? =x
neutral, rev to redline, slam it into drive
The guy is like 40+ and had it since brand new. Even though he only has one functional eye, he can drive. :P
LOL!
yea its shocking isnt it!
made a point of speaking to my non australian immigration officer (!) that i was guaranteed acceptance on a last remaining relative visa, and simply chose the partner visa because it was cheaper.
tis dog shite.
yeah it's farked
Although so far everything is going ok on our side, they took out the $5k or whatever it was from the account and haven't heard anything from them
Scotty, do you have any 33 ones laying around to suit a stock airbox? I'd love to test fit one to see if I can handle the intake noise increase, considering its my daily I don't want it too loud so don't want to buy one from you only to find that I won't be using it.
atm I've got the stock pipe with some of the flexy bit removed and some 3" zorst steel clamped in, think it could be my restriction...
LOL!
yeah it's farked
start getting evidence toghether. they contacted us a year from taking the money. ask for all sorts of shit. then a year after that is when they process the permanent part. which is what they are doing now.
I had a 4" steel intake and you could hear it but the exhaust is louder anyway... Also with the HKS turbo the sound was fkn awesome
And just how visually obvious is it? There's currently only about 1cm of the 10cm of metal pipe visible... and only from a certain angle, and its in shadow.
Could I just paint it black and have it look almost compreetrey stock?
Stock BOV not blocked off.... currently "ssshhhhhh" or "peeewwwwwwwwwww" depending on the boost/gear
How much is one of these Great Scott intakes for a valued and handsome SAU VIC Member such as myself?
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
