I've had a bike do that to me before; slammed his brakes on in front of me and looked pissed off when my car hit his rear wheel...what the fk did he expect to happen!
There was one on jalopnik recently too, on a freeway - needless to say the bike didn't fare well
I still think there's a lot more to the story. If that was the case and the above happened, instead of beating the shit out of him, wouldn't they put him under citizens arrest(or some other stupid American law) until the police arrived? It's like pot calling the kettle black. And in the initial run over, it pretty much does look like they surrounded the SUV. What else would you do with your kid in the car.. I'm surprised no one pulled out a gun.
exactly. they have it on video.
like i said, pot calling the kettle black. theres too many holes in it to be one sided for the bike group, where it makes a lot more sense for the SUV driver to be put in a compromised situation judging by the amount surrounding.
They weren't, but it was no misses, no hiccups, pull after pull after pull, hours of it... IC was cold, AT Cooler was...room temp.
240kw @ 4000... and 310 at 4800...and 5k,6k,7k, 298 at 7500 etc. Did lose some boost, 26psi in middle, tapered to 21-20... prev run was 24? at redline.
Did a 98 run, 26psi (down to 21-22) and made 250kw lol. Same graph shape, though. 16+ deg of timing and no pinging.. 22 or so on E85.
Nothing of note changed (well transmission build occurred/new trans but went from a built NA to built turbo one).
Fingers pointed at IWG blowing open or manifold, or turbo being choked, though no reason as to why it should be any different than before as nothing changed...
Should prob clarify
First trip time, 20psi, E85, made 310
2nd trip/retune, 24 psi, E60, made 340, ran out of duty.
3rd trip/retune, "26"psi (down to 21?, E85, made 310.
Prob seems due to boost, but nothing changed :P
i know my emo makes a big difference to power if you can keep extra boost in it to the limiter.
is shingeki really that good? its all despair and gore isn't it?
oh yeah newish roast duck joint @ box hill called roast duck inn is pretty good too, up there with rock kung or might even be better, though i dont think they do peking duck.
soup dumplings are pretty damn bloody good.
good guy NAB
Well I was technically referring to my Ops Manager but i didn't really make that clear :P
Dat hub dyno reliability
only thing more reliable is your mother
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
