Vic Wasteland Thread
R31Nismoid
Will go looks amazing for $50
N64 are like $150 now FFS
managed to get one with mario cart for $100... ghey but since mine got thrown out by accident it had to be done :/
That's alright
@Plattsy I actually do think snes are holding more money anyway lol
and if i asked a male mate to that place, would it be considered ghey?
No, it could be two mates going out for a beer and good tucker.
This is ghey... :P
Wont be running E85 just yet if thats what you're asking. Not many documented, tracked pulsars on E85. I know of one, and his hasnt run the same since. We'll see how this setup goes with the current turbo first on 98, and will weigh up E85 later.
yeah, sweet. bike riders running around like they own the roads, stopping traffic, running reds, wrong side of the road.
pretty sure none of it would have happened if they just let the dickbag in the rangie go past them instead of taking up however many lanes.
i cant say what i would have done in his situation, but it would be pretty intimidating being stopped by what looks like 100 or so bikes and having them all approach you.
i'm not on either parties side, i just think they all acted like a bunch of dick bags, (including the rangie driver) and it all could have been avoided
who is this and why is he on the fence?
As you can see, there's a bitch in his way, that he needs to move.
lost it
http://www.news.com.au/national-news/victoria/woman-dies-10-in-hospital-after-toxic-chemical-released-at-sunbury-motel/story-fnii5sms-1226732023320
For what purpose would someone in a motel release Hydrogen Sulfide and what is it normally used for?
fart gas
any body wanna play indoor soccer on friday evening in frankston. theres a couple of guys needed.
ive been six times, and havent had my car stolen or been stabbed. its good fun actually.
then again if i was a dodgy kent i wouldnt try to stab me either.
    • Wait, the flappy paddles or sequential is the small penis indicator?  Either way, I can't afford it.
    • You and me both. If I ever get it running again, I'll have to look into cruise control.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
