car looks good hamish
looked at another evo 8 today
asked him on the phone, whats wrong with it, smokers car etc? nah all good , no issues, non smoker
rock up
smelt of smoke, cigarette in the ash tray
wouldnt go into reverse properly
bonnett doesnt line up
rear bar different colour
both diffs clunk going at low speed around a round-a-bout
at least it had no rust
fkn lol some people are just dream boats
the first one I looked at was probably the worst car I have ever seen... never reg in aust and was clearly an ex track pig in japan:
evo VII
- rust... rust everywhere
- stereo missing
- harness mounts still in car preventing seat from moving back
- seats ripped and bolster destroyed
- every panel from a wreckers from a different car
- every single panel a different shade of white
- no panels lined up at all
- both rear tail lights cracked
- rear smashed in and badly repaired
- front smashed in and badly repaired with visible welds in engine bay
- guage mounts on car drilled into dash
- sound deadening removed from underside of car
- entire bottom of car completely rusted and half assedly sprayed black before sale
- odo clearly wound back by 100,000
- wheels cracking and rusted in parts
- engine clearly returned to stock for export from j-land (all bolts rusted and seized except where performance parts bolt on (turbo etc)
car looked mint in photo's.
guy was asking 19k and wasn't willing to drop the price a dollar lol
he got angry when I told him why I didn't want it and that I wouldn't even pay $5k for it
told him to sell it in parts if he wants to see even 10k
I drove 1 hour to see that piece of shit :/
Can confirm food by Vu De Monde chef was awesome
sweet... details of any sort to follow?
When I put in two wheels (18x9.5, or 17x9 (same rolling diameter with tyres on)) into the back of the 33 with rear seats in, it pushes against the trim panels squeezes them in about 1cm... So two wheels car sit side by side just fine and then two more stacked on top...
Not sure how they'd go standing upright (same orientation/direction as if they were on the car), but I don't put them in like that in case I need to brake hard :P
If I'm just putting two wheels in the back seat, I normally have one sitting flat, and the other sitting on an angle on top of it. Doesn't push against the side trims that way.
Leather jacket and watermelon
Bacon & Eggs
Chicken with something
Steak with something
Granny's apple, gingerbread & milk
I must say all dishes were amazing just wish there was more
I could of had a big mac afterwards. But for top quality food for $50 can't complain
  • Like 1
E85 economy is as follows
44 litres cost $53 today and netted me 238km, with fairly aggressive driving as per dat newfound power.
From this, we can deduce that 400km (my usual tank fill up point on 98 unleaded) would require ~74 litres at a cost of ~$89, which is only a few dollars more than I would spend on 98 to get the 400km (probably just over $80).
Be interesting to see if E85 and 98 sit on par for cost at my next fill up, given less aggressive / more daily driving with the current tank. But so far...
In car news, yesterday arvo was in my mate's car (8mr) and went up to Arthur's Seat for kicks as we were nearby in Rosebud... Nek minnit, R32 skyrice getting very much sideways action going on chasing us haha. Dem ballz.
Also saw what I think was one of those ferrari/lambo experience days.
  • Like 1
Bacon & Eggs
Looks awesome! I want!
you do realise you are like 4 years late on this yeah?
You do realise fuel prices ain't what they used to be?
Ain't what they used to be, ain't what they used to be
  • Like 1
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
