Tyres do harden in the weather and tyres on cars are through heat cycles that help to keep them from hardening. The latter part may be total shit, but it made sense when I made it up.
Regardless, distributors note year of manufacture and sell older stock for cheap for a reason.
Yeah was thinking that too but got to consider tyres aren't made yesterday. Would be coming via boat from china which is months and by the time you buy them, they have been sitting for ages anyways.
Could argue a tyre going through heat cycles would cause more wear as it's expanding and contracting.
hmmm.... it's just that I've got an old set of tyres in the backyard out in the open, used to be in the shed but needed that space.
So two sets of wheels with tyres on both sets, and I want to swap them around.
Would they charge the usual or double because they're taking off and putting on twice?
I've got a pair of jack stands if you want to borrow.
Haha saw that today. Classic
Slow and annoying.
Bought a 34 GTT, saving up for another gtr or o/s trip.
You really need to just buy a car and stick to it
Hmmmm, what are AD08's worth in 265/35/18? Any good place to get them from, fitted, in South East or Bayside or even Dandenongish area?
Cheapest AD08's would be about 380-400 fitted
The newer AD08R's are $450-$500 fitted
O/S
play with cars later
I've done both before, think I might do both, can always sell the 34.
The o/s will be short burst not 3+ months like last time.
It's wishful thinking really, blame it on my attention span and genes (father switched cars a lot, grandfather does every year before retiring).
I mean to actually swap the tyres from set 1, put them on set 2, and the tyres on set 2 to put on set 1.
Just jack up the car at each corner and swap each wheel one at a time. Will take 10 minutes tops...better than a car place doing it. Have a wheel brace if you need it.
I think young Jonoe meant taking tyres out from wheels set 1 to wheels set 2 and vice versa.
Costs me $5 a corner to have tyres swapped, $10 if I want them to get rid of the old tyres, seeing as you're keeping both sets though that's not gonna matter.
The benefits of living out in sticks, low overheads.
keep putting off doing research/pricing into semi's.... will wait for my RSRs to disintegrate. Probably wont go RE002s again either cause they pricey for what you get, but then again I dont really do enough kms for wear and tear to be a problem (other than -3.5 camber wear)
cool 7 degrees and wet on Mt Dandenong. yay
this dude snuck up on me earlier. abdomen was bigger than my thumb
Abz where are you?
11degrees in melb ATM but being in the office and judging by the current status of my nipples, it's roughly 23.5 degrees.
hahaha lol'ed.
meant body temp with this constant fever. :/
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
