haha naice! do want a ride, never seen what an ES is like performance wise, only been in a emo7. :P
hen i must be /sickcurrylyf
Coming parmas on Wednesday?
Also hadn't driven the ES in like a week, tried to start... nothing... was a sad start to my morning. Got back from work and jumped started, and went for a bit of a spritz tho, smiles all round :P.
do try it
lol'd! brill.
  • Like 1
lol'd! brill.
hopefully brah if i'm feeling alright, wouldn't wanna get everyone sick! and ahh that sucks, needs a new battery?
this is true, if you get me sick before exams, somebody gonna get a hurt real bad lol
mm dunno , will just have to keep an eye on it i suppose.
  • Like 1
Basti, on 19 Oct 2013 - 6:11 PM, said:
Just saw a stretch vl limo with a walkinshaw kit. All of my wut
Pretty sure I saw this or something very similar near Osaka imports.. there's a limo repair shop near there.
Pretty sure I did a Patrick Stewart quadruple take of wut
ship2anywhere.com.au is the cheapest i've found.
but your item is pretty large...... sooo.
$686 still lol
Ask whoever sent yours in first place? Or is it 'Australia' tax on postage?
Yeah was sent by a UK company they only paid 75 pounds for some reason
$686 still lol
Lol at $686 postage.
Try asking the mob you bought the fenders to organise postage their end and you pay?
I gotta move to different store.
Spotted my old R 5 mins after finishing work, didn't realise until I saw superlaps...
Anthony, if you happen to be reading this, what kelvin are your headlights?
am readin.....will respond lata bro.
Bed time now
Peace
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
