umm 12th of Nov, wbu brah?
haha thanks one of my fave moments, he definitely was the best, dem feels when he died and also when gisele died. :(
Nov 15! Can't wait. Although currently the first day of SWOTVAC has been spent in bed so far... gg.
Man too many feels.
Nope, saw Rush last night at the movies.... Very good :) Highly recommend seeing it
Yup I thought it was a great movie
Watched a documentary afterwards and it was like watching the movie again haha
Man too many feels.
Niceee not long to go! Same here bro hardly studying so far but one good thing is my xbox power supply blew yesterday so yeah perfect timing lol. :/
Breakfast in bed too hipster man?
yeah had a pb&j sammich tbh. wholemeal so it was healthy? RIGHT? RIGHT?
Exams start in 1 week, so an official goodbye for me until the 6th of November :sad: ;(
haha, you'll be back for procrastination... :P
haha, universe helping you out dude. but yeah study mode has yet to be activated :/
PB ain't very healthy, lol... We did an experiment in science back in high school where we lit peanuts on fire and measured how long it took to use them as fuel to heat up beakers of water...
There is a LOT of energy (fatty fatty fat) stored inside peanuts. they're actually quite flammable too.
Centreline suspension finished their little Ford. been around for a while but now with aero and turbo lol
230kw and 650kg. jelly.
Lotus who?
Nice, briefly had a laser.
Haha I don't consider pb&j to be healthy, that was the joke :P
PB is not bad though - healthy fats are just as important in diet. And some good mono+poly unsat fat to be had from PB. Everything in moderation, of course :)
So car got defected last night as my friend took it out for its weekly Sunday night drive.
Got done for wheels protruding, height low (hit the sump guard undercover & rear number plate bent.
Anyone have roadworthy stockies? Mine are in w.a lol
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
