Not quite that simple.
Was orginally put together when Tickford was bought by Prodrive (UK) and started a partnership alongside Ford. Wasnt until 2012 that Prodrive ditched FPV and it was soley operated and owned by ford.
627.jpg?5784
LOL! @ Photo!
Winton first time today. Off the top of my head.
Session 1: 2:03 - didnt know what I was doing
Session 2: 2:00.7 - slowly learning
Session 3: 2:00.9 - did same as last session. Didnt know what to do to go faster
Session 4: 1:57 - newbish friend helping me out with a few things I was doing wrong
Session 5: 1:55.5 - more experienced friend showing me lines for sweeper and s turn
Session 6: 1:53 - missus as passenger. Improving on what my friend pointed out with lines and braking
Not bad for sub 50 odd kw on re002 for first time. It has more in it as is. But no more track time. Will be back next time to improve! As is I think I can get 1:51-1:52 comfortably
Mate with same set up but with k24 e85 160fwkw was dipping into 1:42. Wtb mo powarh
Impressive time for your first time out in the Civic Jonoe :thumbsup:
Was keeping at eye out for your times on Natsoft haha
Should buy a GPS and datalog your lap so you know corner speeds etc..
weather so good. hopefully holds out similarly until thursday despite the weather reports, got some go karting planned :D
might give the bike a wash now actually. free days ftw. well, until work :(
Tony/Alvin/other 34 owners I don't know who, do you have issues with fuel gauge?
Mine is acting funny :/ Mike reckons it's sender that needs cleaning.
Filled up and gauge shows empty with low fuel light on...
sender out and clean mate. shit job. my 33 did it.
they do not.
thanks mate.
ran some autoglym aircon sanitizer through the system - wanted to make sure on the off chance, that i would change it over too but no need now :D
Tis what Mike told me, just need to get his arse in town...
I've got to hope the trip meter doesn't shit by itself, currently relying on it to work out how much fuel I've got :P
lulz.... me and dave are rubbing th emicra on sat afternoon round mine if your free come down? we can help fix yours. and by help i mean stand there drinking beer telling you how your doing it wrong. can also pick up cat... :woot:
I should get one. Haha. Does natsoft update live? :0
Hmm.... No idea how long it'd take me to do it myself - I suspect it'd take 5 months to do it.
I have work Saturday, so if it takes 30 mins, I might could pop by?
anyone know if r33 gtr or r33's.. have aircon filter / pollen filter located behind the glove box?
ive read some people saying yes, others saying no..
Late cars do, earlier cars do not, best bet is to pull the glovebox and take a look.
Scotty you weld ti?
Can't open the tank, pull it out, open it, clean it, put it back in, and get the fkkkkking screw sleeve back onto the tank within 30 minutes.
Each time its taken me ages.
Yeah, and I haven't bothered to find where it's located in the 34, I think similar spot to the 33.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
