ok thanks man. you got any old 14's or 15's lying around?
I havent got anything sorry
How much you looking to spend? Theres a few wheels for sale cheap on PGA. Check it out or make an account.
Go suss it out i reckon, tho drift sales usually has some big lemons for sale on it this one looks decent! Kinda looked like he had P's up in the pic he posted but think it was the rego sticker diff colour with sun glare. Maybe compression test and what not if you buy it incase? MP 33R's are baws. :thumbsup:
You're right it was a green P Plate, a bit suspicious of that but should be okay, it's a GTR after all, not made to be babied (and I'm a P Plater and don't really thrash either).
Will make sure I get it inspected at work before any money get's handed over as well. Does look nice though!
  • Like 1
you know you're not meant to inhale it ,right
lol :P
painted my front grill as it was flaking a little, looks awesome now!
also gotta get you to come work on my car soon Artz! ive been lazy with getting you to have a look at it!
Yo Plattsy,
Those r33 front inner guards you're selling in your FS post, are they the black plastic guard liners in front of the wheel, and the bottom of them extend forward towards the front bar?
If so, want, shredded mine the other weekend while overtaking on the hume, popped out and ground away to nothing on the wheel :P
  • Like 1
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
