My VL's fuel gauge (and probably everyone else's) used to intermittently stop working. A good slap of the dash would bring it back to life usually. Finally got fed up with that and pulled the cluster out, turned out there were a bunch of cold-soldered joints that had cracked. Re-flowed them and no more worries :yes:
I thought of doing this 12 months ago. storage/security/tools are a bit f an issue unless strict rules are enforced.
car is at tuners for run-in. thing won't idle when warm... suspect AFM has finally carked it :( bought one from a member literally 2 days ago. hope I get it before this weekend...
vic club should hire one. we all chip in 10 bucks a week, or 20. we have lift installed, and we all have to book in to use the workshop.
I'd want to keep my car there as well, since I don't have a garage :D
Huge liability issues right there, I doubt SAU Vic would wanna get involved in that without some exxy insurance as they could pretty easily get sued...but it isn't a bad idea by any stretch.
Just get a couple of people to chip in for a 1 year lease up front, get address and drivers licence details, install a security camera and away you go!
yea i get ya. but if we leave it empty...... some one would be there every night working anyway haha!
im down for weekly payments. no up front shizzle tho! but only if its got a lift~
Can pick up a 2 post hoist for $3k or so I think...
I know a few blokes who share a garage in an industrial area in a similar way, seems to work for them and it makes their girlfriends happy to not have all the junk in the garage ;)
everyone on the internet is just like "just solder the contacts on the AFM, its a piece of piss" "Z32 AFMs often get bad connections, just open it up and have a look"
no one tells you how to open it or how not to open it. if mine wasnt f**ked, it certainly is now lol
anyone know where i can get one locally even if its a bosch one?
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
