Vic Wasteland Thread
R31Nismoid
Duly noted, thank you peeps. And thanks for the butter recipe Ham. Omelettes are badass and their simplicity and low mess make them win at life. My omelettes are so busy I have to use a handful of cheese as a binding agent or it goes Hindenburg on me...
Would love to add vegetables for texture, but I don't want to mess with my all meat tastes. Parsley as a pub meal garnish is as far as I would go!
the humanity
Waxed bonnet, then cbfed the rest of the car so now I have a nice smooth bonnet but nothing else :D
Dat arm / shoulder workout rubbing that bitch off
Edited by UNR33L
Yuck what for?
was driving normally 5th gear doing about 70-75 in a 80 zone coming back home from work literally 2 mins away from home yellow one pops up out of nowhere tailgaits me puts the lights on and shit. Partner was a good bloke but main guy was pretty rude. He warned me for my rear licence plate for being bent and unable to read from a 45 deg angle. Got a fine for driving manual on auto licence (my fault for not booking my test sooner so not complaining left my car at site and walked home) but also for "failing to display p-plate rear" even though it was up and on factory uv cut tint that has passed Rwc he said he couldn't see it and gave me a fine and 3 points....I was on 1 point before this so licence is bye bye unless I contest. :(
I got done for the EXACT same thing.
It would of been 4+ years ago, on my P's in my N/A R33 just when green P's were just introduced.
Pulled over - done for manual with auto license (had the re-test booked but you know vicroads delay and what not, fair enough $150 and my fault) Then also said P plates not displayed cos you couldn't really see them that well through the tint, and with water on the rear window. $150 and 3 points for that as well, I wrote a letter to Vic faggotpolicegayflamin mongrels and got out of the P plate thing. From then had to display them on outside of car with magnetic P plate on the back which were sometimes taken but meh.. got through my Ps eventually.
Then got a 33r off Ps, random EPA etc in the mail and just had enough in general sold up and got a ford, buy a ford. inb4grant
No points at guessing which flamin mongrel pulled me over ;)
Edited by UNR33L
  • Like 1
    • The only requirements/issue with one piece tail shafts is tail shaft RPM, the length of it, the diameter of it,  the pinion angle, and material used Daily driving at 110 kph it top gear with a one piece will probably never see any harmonic issues at ???? tail shaft RPM, but, at 200kph you might see some harmonic issues if your tail shaft isn't spec'd right I looked into this alot when I was looking at a new tail shaft for my VX SS after it constantly flogged out centre bearings and getting vibration over 160kph, in saying this my "pinion" angle from the gearbox to the centre bearing was the issue, slightly to much angle caused the centre bearing to flog out from harmonic vibration at high tail shaft RPM, but for me the issue was the 12mm lower engine mounts, after getting the angle of the dangle from the transmission to the centre bearing lined up correctly, and to within spec (OEM height poly mounts), the car is happy at 200 kph (125mph at the drags) now even with the OEM spec centre bearing and rebuilt OEM 2 piece tail shaft What's your tail shaft specs?
    • One of the issues Adam mentioned was the tail shaft center bearing being flogged out, I took the shaft down to be rebuilt after a conversation with the owner of the shop it was decided a whole new shaft was the best way to go.    so after taking measurements and waiting a week my new shaft was ready to pick up   new and old shafts next to each other, yes the new one piece shaft and was worried about vibration, after driving the car turns out that there is nothing to worry about
    • HOTGTR r35 - down next to indro shopping mall
    • For sale is my 2002 VX SS LS1 Commodore  $30,000 ono 160k km Located at Holsworthy 2173, NSW Extremely clean car and well maintained  I have receipts for all work done, and I've had alot of work done, and more money spent than I care to remember on the build Car makes around 500hp at 7 psi Harrop 2300 supercharger with FI induction interchiller installed and tuned by Autotech Engineering  Mild cams, and PAC valve springs Automatic 4l60e transmission was built by Craig's Automatics  Harrop Truetrac LSD with 3.46 gears  Ceramic coated 4: headers, 4" exhaust with Varex rear box RaceTCS traction control Engine serviced every 5k km, transmission serviced yearly, diff serviced every 10k km Some spares and parts will be included  There's lots of other stuff done over the years I've owned it, like new brakes, coilovers, starter motor, sound proofing, head unit with reverse camera, alarm, just check out the "Bogan Cruise Ship" build thread for everything that has been done and specs of parts used, apologies for all the other random stuff in the build thread, there's a few cars, and a bike in there, but, if you scroll past the non relevant stuff there's all the work done Car is currently stored undercover at my work, you will need to have a current driver's licence to get signed onto site to view the car as it is a secured site and I will need to sign you in through security  Any test drives will be within this site I'll post up more pictures next week after I service it and detail the car 20231108_170005.mp4.7b8746d1a41f6d4a6fe0b64232f506ab.mp4   No I don't want to swap it for anything If your serious about looking for one of these, check out the others available, then come look at this, then we can negotiate  PM me for further details and timings
    • Cold start, battery is one I got with the car and dead! Jumping is required as it won’t hold charge and yes the alt is working  IMG_8373.mov
