Just got that fun "go kart" feel that you get from a little buzz box; cockpit interior, in tune with the vehicle controls/feedback. You have to hit the corners though. They are no more special than a sporty little modern-looking car around town. I think they did a good job of capturing the essence of the AE86, being that it wasn't the fastest car at the time (still decent performance), but people loved to thrash/chuck them about. A lot of Hondas like the Integra and Prelude are like that. Would I want more power from factory? Yep. But it stands on it's own where it matters. Be a great beginner track car if you can afford to spend that on a track car.
Add a blower and I think that's the difference between 8/10 and 9.9/10.
Hmm... So for just cruising from/to work with squirting there and there, I'd better off keeping my 34 instead no?
Clever security too :)
Xray machine showed a slight gap near the top of the piston...they got greedy and made the cavities too big.
Depends. In the end it's a newer car, more comfortable and better looking than a Skyline. If performance is what you want and you're driving to and from work, keep the Skyline. Like I said you gotta take it to corners to feel the performance side of it. Without corners it's just a good looking sporty coupe with some nice modern features and interior.
I should be there.
And Dezz e60 M5. Dat V10 noise! Drool!
Awesome! Keen to see your 34, looks dope in the pics. :D
I'll make a post about pre meet tonight for anyone else interested.
Haha bit of wider fenders, plastic dip and some rims and shell be sweet
I considered getting one as a family car in the future. But hear maintenance costs can get quite high if something goes wrong. Especially the gearbox
But I love the sound of a V10 :merli:
need some Neesan help
2 plugs near IACV. one brown, one purple. Mein car has brown plug ok, but nothing to plug into purple plug. and engine-conversion loom doesnt have one nearby that fits. Any idea what they do?
(theyre right next to each other)
Yeah purple is definitely a solenoid, I remember replacing the copper washer on my 25, Not sure what the other bit is but I'd imagine it's probably the part that actually moves to open and close the AAC valve, from memory there's a spring inside that area. Manuals and FAST don't go into any detail about what's what because you're supposed to just replace the whole unit when it breaks instead of fixing them :/
Will be properly looking into these supercharger kits for the 86 on Monday. From what I gather: 4-5k fitted, ADR complianced and engineered, all bolt on components with ecu reflash. 170rwkw without an exhaust on conservative boost; not uncommon to get 210rwkw from an exhaust and a little more boost. In a great handling 1200kg rwd, that's good/dangerous fun!
So a r32...? :P
Looks like I gotta find one to drive and see what it's all about for myself.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
