Vic Wasteland Thread
R31Nismoid
Has he got a good rep? Is he a pro?
Is it just me being paranoid of a guy coming to your house to install an alarm in your car lol?
I also need mine sorted out. some can vouch for how ridiculously loud it is and it automatically arming everytime the battery is disconnected is a right kÜnt to disable it.
Was planning on taking mine to Southland Auto Electrical, and its been recommended by SAU. (also to get battery drain sorted)
Oh haven't heard of them
And i did SAU searches too lol
If only Chris Rogers was Melbourne based!
Ha, this is a 3 minute walk from my work, I've had a few small things done there...
They don't just do Electrical either, they did an engine swap on a workmates Beta-Romeo GT and did a good job with it...
But when I first went in there it was to ask them to diagnose my jumpy tacho (the normal r33 problem, before I knew it was normal) and he said it'd be about $1000 in labour since they'd need to pull out the entire dash to look at all the wiring.... yeahrightiom8byebye
0-100 times is exactly what its designed for. drive one and see, the gear ratios are highly annoying for street driving and not balanced enough for track use. interior is cheap and uncomfortable and steering wheel isnt very nice either. You'd struggle to fit a seat of your choice in there because of the tiny cabin and restricted sitting position. The steering wheel size is comparable with a go kart, but you cant get any bigger because otherwise you wouldnt get into the car. No matter which direction you look, the view is restricted, even the front windscreen. blind spots the size of trucks and cant see out the back of the car making reverse impossible. I dont even know if there is a factory option for reverse camera.
im 5'10 and it was squishy. no fish eye in this pic
One of the nsw Guys has an exige as his daily, he loves it.
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
