dun matter...
it wont be a writeoff for that... just likely to be a quote the ins co will refuse lol
as I was insured with shannons they authorise mick to do the work THEN give the quote to the at fault party and let them deal with it.
Can any brahs recommend some panel beaters in the south east? Need to get some quotes for insurance. Don't want my car written off so no micolour pls (looking at you Pat)
You can try DT Panels, but his pretty busy atm if you needed urgent work done
So if her insurance co are going to tell me to jam my quote from micolour, why would I bother going there? Lol
Having to drive around to panel shops after some careless tart smashes into me is inconvenient enough
You can have whoever you like in your insurance list to fix it, if you have choice of repairer then you can choose whoever you like. Your insurance pays for it, and then claims the amount of the at fault party. Your car gets fixed by who you want, if the at fault insurer refuses that isn't your problem, your insurance company will have that argument. That's why u pay for insurance.
To my knowledge you can have anyone you want repair it anyway. You're not held to ransom by their insurance company or having choice of repairer on your own policy. It's not your fault if the other party that hit you has cheaped out on their insurance or not.
Hence you can have it repaired wherever you want and you can refuse their company's quote / place of repair. Their insurance company do have the option of settling it in VCAT if they think your quote is too high and refuse to pay it, though. However, unless it's ridiculously high they will likely just pay for wherever you want to take it and not bother with contesting it.
It's like people thinking Just Cars will force you to go with a repairer from their list. It's actually illegal to do this, to my knowledge. Had a panel beater tell me this, that they just word it cleverly in their PDS to make it sound like you have to. All they can do is contest a quote they think is too high, like every other insurance company. So when I had repairs done, that's exactly what happened. The Just Cars assessor said if I really wanted to I could go with my quote. I ended up choosing theirs because, when I looked at the finer details of the quotes, their recommended place was actually going to do a better job...
Conversely, you also don't have to be satisfied with their repairs and can contest that. Remember legal studies Ric; the law seeks to restore the status quo. If things aren't the way they were before (and you wouldn't even recognise me anymore), you have the right to challenge it until you are satisfied.
Oh and get a hire car for free out of the fkers too.
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
