yeah... although there is literally no passenger seat left... the pole went right through and is where the drives seat should be.
I can see him walking unfortunately :/
Coupes are more expensive yes. I completely forgot about getting some prices for you. Sorry man. Will check in the morning and let you know
I thought the same sedans look heaps better
Sweet no real rush not like I'll be buying next week anyway but send em over whenever you get a chance so I know if I'm dreaming or not...
Sedan it is.
The only reason why I say not with instructor is because of price. They usually charge 1 hour lesson beforehand + vicroads, so $220 all up
It's pricey but so are retests...I considered it insurance at the time. My instructor and the tester were old mates and the instructor was telling me he hoped we would get him haha.
So yeah, in short, I shouldn't be on the road.
F6 310 or FQ 340
e8MR or e9
with almost no money spent is quicker AND more responsive than FQ
and F6 depends on how much you want to mod
my 7, the money has already been spent. its clean and rust free, aaron also checked it out when it was forsale in vic.
http://www.skylinesaustralia.com/forums/topic/436461-2001-mitsubishi-evolution-7-249kw-on-98/
Abz, I don't think they'd fail you straight away but depending on the square you get maybe they'll be a bit prejudiced / tighter for it...
I just used my mates impreza (just an rs) for the test lol
Cheers for the advice brahs!! :) Yeah got done for driving manual on auto licence so going for the test this friday. RACV peeps all on holiday so imma try someone else tomorrow but other than that i'll just take my mates accord euro, no point going through all the hastle in the skyline plus scraping at vicroads lol.
remember to double clutch and not granny shift
but he no buy, so not good enough?
Who was the bloke that tried to sell me a set of tri spokes that isn't Niroj or Mike a while back?
It was white late model tris in 17s from memory?
I want white tris now. Halp?
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
