you know who got the numbers and CVV on the Austrlian government MasterCard? aboriginals. $6.2 billion a year. ouch.
I didn't know much about the Marbo stuff and land rights. who needs casino's eh?
don't teach us that history in school. all we copped was federation and some other stuff I've wiped from my memory.
the government has started a program by contracting a company to setup 32 General Stores in outback areas with aboriginals, and sell decent foods to encourage and teach good dietary habits. the people who apply to run the shop get a house to live in and $52,000 a year to run the shop, regardless of how much money the shop makes. the contractor supply the food etc and the government foots the bill. not including that a lot of te aboriginal income spent at the shops will be from the government too.
Hey guys quick question not worth starting new thread over:
1. Im buying a z32 + nistune with r33 base tune, do I need a z32 afm to run it or does the ecu work with the stock afm?
2. Anyone running a z32 ecu in their r33? Im getting mixed reports now, where I thought they were a pretty seamless install.
Fanxxx
z32 pinout is different
same physical diameter, different pin mappings
also which rb25?
rb25 S1 is 5 pin and rb25 S2 is 3 pin
z32 is 4 pin from memory
but its all the same
power,ground,signal is all that matters
i maintain my opinion that the new 5L ford engine is awesome. so easy to make power out of it.
dam straight!
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-frc3/291365_10150980217398779_1483653352_o.jpg
dat 240km/h in 4th lol
that's a roller dyno too Hamish, not one of those darn happy hub dynos :P
nah but srs
Edited by UNR33L
Back to work today
Ah to late for me
I just went with another shop which was Chris's best recomendation
Don't paint all aboriginals with the same brush from your experience with the city folks you may have run into.
The ones causing trouble are usually the outcasts who have no respect for their family and culture.
Had a good chat with an elder who explained the above.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
