you know who got the numbers and CVV on the Austrlian government MasterCard? aboriginals. $6.2 billion a year. ouch.
I didn't know much about the Marbo stuff and land rights. who needs casino's eh?
don't teach us that history in school. all we copped was federation and some other stuff I've wiped from my memory.
the government has started a program by contracting a company to setup 32 General Stores in outback areas with aboriginals, and sell decent foods to encourage and teach good dietary habits. the people who apply to run the shop get a house to live in and $52,000 a year to run the shop, regardless of how much money the shop makes. the contractor supply the food etc and the government foots the bill. not including that a lot of te aboriginal income spent at the shops will be from the government too.
Hey guys quick question not worth starting new thread over:
1. Im buying a z32 + nistune with r33 base tune, do I need a z32 afm to run it or does the ecu work with the stock afm?
2. Anyone running a z32 ecu in their r33? Im getting mixed reports now, where I thought they were a pretty seamless install.
Fanxxx
z32 pinout is different
same physical diameter, different pin mappings
also which rb25?
rb25 S1 is 5 pin and rb25 S2 is 3 pin
z32 is 4 pin from memory
but its all the same
power,ground,signal is all that matters
i maintain my opinion that the new 5L ford engine is awesome. so easy to make power out of it.
dam straight!
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-frc3/291365_10150980217398779_1483653352_o.jpg
dat 240km/h in 4th lol
that's a roller dyno too Hamish, not one of those darn happy hub dynos :P
nah but srs
Edited by UNR33L
Back to work today
Ah to late for me
I just went with another shop which was Chris's best recomendation
Don't paint all aboriginals with the same brush from your experience with the city folks you may have run into.
The ones causing trouble are usually the outcasts who have no respect for their family and culture.
Had a good chat with an elder who explained the above.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
