Ma Nigga
No wedding for me. No kids either
Just $$$$$$$
666e8b064728e9605e3fd677083ab3ea87bc6727
You got a house to yourself yeah? you best be making a 'games' room with a big ass pool table, bar, etc.
Edited by UNR33L
  • Like 1
Ma Nigga
Just $$$$$$$
do you wonder if life may be unfulfilling without family / kids etc?
not having a crack just curious
i mean i never thought i'd have or want kids etc but i dunno the older i get i think it would seem a bit pointless
Edited by alr33x
ditto.
but fark marriage. de facto all up in here
once i found out youre supposed to get an engagement ring AND a wedding ring... it was the nail in the coffin
Got a poker room but rarely play these days
The way I see it I'm too f**ked up to be in a relationship and definitely not a good candidate to be a father. It's not really a choice just the way it is, so no choice but to accept it and get over it. I'll just have to find other ways to make it fulfilling, most likely with material possessions
Kid I went to tafe with had a VL, got a small branch caught underneath it and it fell out just as he went around the corner then stopped to investigate. Watched him poking around down there for like 10 minutes before I put him out of his misery :P.
its still run in.
we'll see what happens with new turbo. will probably rev limit at 7800 or something, wont be much torque up that end but cams will probably be still going.
but used to be
I used to think same... but EOTD it's something you will want eventually as we are all programmed for it.
after all it's the ONLY reason we exist.
In my mid 30's now i am starting to see a lot of my mates without kids starting to say they wish they one after hanging out with Orlando
Orlando is pretty fkn Rad though
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
