what if you enjoy what you do? :/
what I get done at work is far more productive that doing shit at home. its more leisurely, but dont get that feeling of having actually done something. Dalai Lama is right, but missed on the important factor of productivity. "back in the day" where people worked to survive or worked (harder than now) to keep family afloat, it was different but now... you can easily do nothing if you want. so productivity and sense of accomplishment are important factors.
Yeah that was just a random quote I got off google
It was more in reference to Ishan
I see too many friends with degrees, who go through all that work and end up either unemployed or just an ordinary job not related to their degree. And as such has been a waste.
So Ishan should work his butt off (doesn't have to be academically) to put himself in the best position possible to secure a full time job after he finished uni
The future; so scary.
But I do agree with points raised. Gotta make the most of this once-only life; career and lifestyle wise.
Human evolution
Sorta reminds me if this video I saw yesterday
https://www.facebook.com/photo.php?v=287437474738184
I agree. But that does assume you won't be productive with your spare time...
Also, productivity and a sense of accomplishment doesn't necessarily = happiness...though it may for some. A life enjoyed can be a matter of feeding the senses, non-stop, with enjoyable stimuli!
I think that everyone should try sitting on both sides of the leisure vs work debate and then decide. Work an overworked and highly paid job; be unemployed for 6 months. Preferably in that order. Then decide where the happy medium lies :thumbsup:
Anyone here work in the city? I could possibly be soon.. I hate getting the train from SE suburbs so would probably buy a place closer and do the whole move out of home thing.. Probably about time hey..
Docklands
Train from Brighton each day...
Easy as
Catching train from SE brah checkin in
I did the working like a dog, and being a bludger for 6 months.
Didn't like both. Must be my shitty job and lack of money to enjoy during the bludging.
So find the happy medium...it's seldom going to sit at either end of the scale...
With what I've got, impossible.
I'll just continue working cos extra cash is useful for moar beers.
St Kilda Rd. I drive because I get home quicker in the evening. Kinda over it though. 12 hour days with travel
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
