Between that and cams it would almost shut off at 800rpm
Cams can affect vacuum to the extent it is difficult to idle, good chance that was your tractor's only issue, other than the driver... :P
My 1000's idle perfectly.
It was probably more so cams but only started after injectors.. Either that or Cihan lol
Bosch 1000s checking in.
Although they're still sitting on my desk, and not installed, XD.
I was going to get ID1000's as well though. Although they're really the same, I think, just flow tested or whatever etc / up to you whether to believe marketing.
Dino fuel lover to e85 guru in 1 tune session. My work here is done. :P
Lol well I was always going to go to e85 just not so soon.
A bit unexpected when Trent says ok lets do an e85 tune whilst where here lol
Going to Daylesford next weekend. Thinking of putting an e85 jerry can in the boot just in case :/
got an email from commbank. theyre phasing out signed transactions, all cards must have a PIN. a win for security yay.
in other news:
http://theage.drive.com.au/motor-news/classic-corvettes-swallowed-by-sinkhole-20140213-32j5b.html
Yeah mine has hunted a bit as long as I've had the car... ever since before the PFC went in (had a Mines ECU beforehand)... It just bounces harder with the PFC I think because it's more aggressive at trying to recover from a low rpm...
With the A/C on, sitting in traffic, it'll sometimes start bouncing 600-1200 rpm with a 2 second cycle... Can see the vacuum levels are fine, but obviously that looks like its bouncing too with the change in rpm...
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
