damn didnt even get to polish it :(
ahah im still a bit unsure if im 100% commited to sell
so if i pull the plug you may just get to :P
you do interior leather protection man?
can do....leather needs regular maintenance more than protection tho...needs them oils rubbed into its hide every coupla months to keep it sexy...
I didnt know GTRs come with leather? I know them uncommitted to sell feels too...want my car gone, dont want to sell it..the duality is killing me :/
i just need interior mainly leather protection
i have had the exterior done with ceramic pro 9H so thats all done :P
To be honest I wouldn't bother with protectant really, leather doesn't stain easy, unless you are a messy fella....just buy some good leather conditioner and apply a quick coat whenever you wash your car...
awesome!
thank you for that!
nah i keep cars very clean inside.. slight ocd lol
ill pick some up tomorrow! :D
yeah if you are clean don't stress too much... they will tell you leather protectant will repel liqiud etc...it will run off your seats..but then what ,its only going to run onto your carpet,..Its all sales pitch far as I'm concerned....the natural oils in conditoners will do much the same as long as they are applied regularly..
So I say why was their liquid on your seats in the first place... :P
but leather does definately need conditioners to keep it plush, otherwise it dries out and cracks...I've seen lots of lowish km euros with rooted leather cause owners don't condition it...
Haha....
you can sit on straight away of you have too ..
...might be a little slippery especially.on your steering wheel and gear knob...dont need to put it on thick though...light and often is better...and often is only like every month or 2....just learn to feel the softness in the leather and you will know if it's drying out...your drivers seat will dry out more quickly of course..
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
