I saw a little toyota starlet the other day at Trent's pushing 190kw, he was going in for an ethanol tune.
There is no way you would expect to get thrashed by a micro car, with a baby on board sticker on the window. I'm all for it. :)
this.
and because i can.
Pretty sure it was 4kg without tyre.
Haha yep. 2nd hand usually better.
When's sau winton day? Going tampered on 10th, I wanna beat my 53, especially when the 53 was my last lap of the day, and the car still had more in it. Gonna have even more in it now due to tyres.
17th May
That might be my first track day of the year. Not sure yet....
Lee dunno why yours weigh so much. Searching up 16x7+42, people saying the 16x7.5+42 weigh 11.1lbs, which is 5kg. Unless yours is 7.5? Dont think any te in that size should be 8kg.
i dunno mang, ive written down somewhere... ill go check my PGA thread.
It all comes down to turbo selection, and yours should be good for similar powerz...
yea ill have the bolts capable of doing it..... but its if the engine can take the hammer this time round....
maybe the next one will.
i know.....
im excited.
need to get it on the road asap.
scotty mate of mine needs his clutch changed on his s15..... he has the clutch already.... wanna pm me a price to fit it for him????
you do clutches right?
I can do anything you like for the right price Platts. ;)
No idea how long it would take though. Is he mechanically minded? I might need a hand... Could save him some coin too.
no i dont believe he is. if im free i will help though.
Thinking of getting a major service done on my n/a r33, anyone know who/where the best mechanic is to take it? Just want to take it to someone whos had experience with these cars before, unless you guys think taking it to a local mechanic will be fine?
Why aren't you sure? Scaredy? :P
Still need to shave the front suspension, fix heater hoses and oil cooler with Scotty Customs sometime :P
Then need to sort out suspension/alignment as Im sure I was hearing weird noises at Sandown. Steering wheel shakes a bit on the freeway. and for some reason the rear left sits a good 2-3cms closer to the body than the rear right :/
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
