Home from work, was sick this morning, but now I'm fine
So spent a few hours working on the front bar I'm playing with to learn how to do body work... I'm scared that it's coming up too well now and I might actually use it as my real front bar :/
Leeeeeroooooyyyyy, can I please borrow your spray gun? I wanna give this a shot.
Also where's a good place in S.E or Bayside where I can get some QM1 mixed up? Also going to need some high fill primer... where to go?
i used a joint in hastings for my qm1. was mint. the clear i got, however was not.
Pretty much I've got ZERO experience with automotive paints, so if any of you guys want to lend a hand or offer advice... please do. Also, will be painted in my garage... I'm going budget here, plastic sheeting to make a makeshift spray booth :D
Sounds like overspray time... You need ventilation and airflow away from the car.
old airport road hawker centre.
shopping?
see MBS, universal studios, our gardens by the bay,
singapore airport, spend as much time behind the customs gates, because it's that awesome.
did someone say old airport road hawker centre?
yep what scotty says.....
you need to keep as much dust way from the paint as possible.....
make sure you get the mixture right and practice on some thing smaller to get the flow right.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
