out at morwell today and had no idea the smoke was so bad from the coal fire going on. you can see the ash in the air, it's building up on the cars. I don't know how the EPA deems it ok to be outside for extended periods.
epa dont know about it.
too busy sending out letters to car drivers.
  • Like 1
sorry to hear. didnt think JZ would be your thing
jay-z.jpg?w=680
Celsior or cressida with 1UZ is where its at for toyotas. JZ's too pricey.
you know big engine toyotas Alvin, what you think?
as mentioned, they're smooth and all, but they lack everything else, power, torque, and are put in cars too heavy for them.
needs turbro in the boot. coolant/radiator set up in the 1uz snorer is stupid, things are overly complicated.
just go 1J.
They issued advice to residents to consider evacuating today apparently due to the air quality (or lack thereof) as they can't guarantee how much longer it'll be like that.
sooo... 892kms on the hilux and it decides to run out of fuel.
stoopid gauge design... ill take a pic later. The needle and lines are misleading. its a terrible dash in general. instead of lines representing 60km/h, 80, 100 etc, it has a solid line all the way round then gaps missing on the 60, 80, 100 marks. actually makes it difficult to gauge if youre under or over speed limit. and of course their lever design reads 500kms in first half of tank and 400 on the second half. f**king toyotas.
Aw, poor you.
Get a pulsar
How many kw can a R33 GT-R fuel pump support in my gts-t? Ceebs going 040...
I've seen them pump out enough fuel to support 450rwkw in a GTR. I've also seen them run out of puff at 330rwkw. Luck of the draw really but will be more than you need.
How much voltage they're receiving is a huge factor in the flow rate (and I'm sure km's also could be a factor)... Wire it up using a relay to get full voltage instead of 15yo thin wiring designed for a smaller pump and you'll be laughing.
  • Like 1
I spy a Simon
Oh hai... Was on my way to the SAUVIC AGM, which was only 10 minutes from here.... or 1 minute if I had turned left instead of right at this intersection.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
