Dudes, when removing the throttle body, how important is it to replace the black gasket between it and the plenum? If it comes off undamaged is it good to go back in?
Would at the very least put a light spray of hylomar on either face just to be sure you've got a good seal. It's a metal gasket and it's designed to crush when it's first used so it will never seal quite so well as before.
  • Like 1
No excuses...it's a Pulsar...if it's not more daily friendly than a Skyline what does it have going for it?!
Birds dont troll the vicwaste, theres abgood r35 thread with your name all over it
that moment when your travel agent misses a decimal point and tries to over charge you 48K on a short trip..
sounds like when I registered the crown, lady thought it was 390000 dollars instead of yen and tried to charge me $16k in stamp duty, 4 times the cars purchase price lol
ah the joy of Au public servant training.
I think I'm at about 5 weeks waiting for a manifold to get put on now, I am a patient man but fffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
I'm patient,,,but more than one day without a very good excuse I would be pulling car out.
Never ever changed or put anything on TB gasket....and i took it off heaps of times...never had an issue....never changed any of my Turbo gaskets either and changed turbos 5-6 times...or cam covers..infact Only gasket i ever changed was ex manifold..
just curious scotty,
how much to do a hard pipe for a sr20?
do you need car?
pm if easier.
I can make a tractor intake pretty cheap mate. :P
Would most likely need the car here, unless you are running a pod and send me some decent pics? Easier to bring the car down if possible, as that way I can be sure it all fits perfectly. Of course, that means you would have to be in the country at some point this year. ;)
Unless they are cracked, I reuse all gasket too. Hylomar is great though. The only gasket that stresses me is the T3 at the turbo entry, as they cop a hiding with exhaust heat.
Well... after a week they hadn't started yet, that was on Tuesday.. put it there because
a) Stao made a booking on my behalf
b) They'd actually put a brae manifold on before
c) It should be simple and relatively easy
I think I could have f***ed it up 18 times after work by now ;)
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
