nice! some good suggestions will be sure to check them out.
keen for a lot of their food places actually, want to check out Dennys
ah yeh that's good you got a mate with a bike trailer how hard is track riding? been thinking about it for a bit but would suck if I came off and binned my new bike lol
do you use laptop for work? should get like a toughbook or something and claim it on tax?
if not you can replace keyboards in about 5 minutes depending on the laptop too
Track riding isn't 'hard'... you just go at your own pace anyway.. Probably wouldn't be doing it on a 20k bike unless you're loaded, but I guess if you're going slow enough the risk is pretty low...
Only use it for work at home, so not like its on site etc.. Due for a new one anyway..
Nismo indicators, should I go clear or smoked? Body colour is black, so I'm thinking clear, but I can't decide.
Definitely smoked. clear will look aids on black
pretty sure my cousin sells them
http://jdmracing.com.au/
/shameless plug haha
smoked will give tuff look, clear will give clean look.
Edited by UNR33L
Yeah I was thinking same thing, probably better off buying a unregged 8 year old cbr1000 or something if I wanna get into it lol
Hows the experience compare to car track days?
So Red Bull Racing (and so Vettel etc) are (or were) at my Uni today.
Guess who was in a literature lecture...
really? would be awesome to meet riccardo i reckon - seems like the type of guy that would answer your questions and not get annoyed lol
gonna miss the f1 :( but i'll be in miami so I got that going for me which is nice.
Enjoying the company of other men?
He is/was here too, I'm told!
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
