Most learned VWL, what's the go with allowing car registration to expire and then re-registering? Specifically wondering if there's any costs / need for RWC? I vaguely recall something about 3 months you can "re-reg" as opposed to "new-reg"... but assuming there is no way around the RWC etc. And if there's any additional re-reg costs... :S
All hard drive brands have their failures. I've got a faulty Seagate in mine, just cbf taking it out.
Didn't we swap that one over or remove it or something? can't remember now :(
I had an early model SSD die on me with a bunch of corrupted write errors, kept hosing my windows install... Friend of mine who built his PC at the same time had the exact same problem so we RMA'd them both... Serial numbers were 3 apart.
SSD Failures vs HDD Failures though, SSD's are awesome for reliability because of no moving parts... The Limited Writes isn't really an issue for home use unless you're using the first SSD's ever released.
^ This SSD SHIT on HDDs for reliability. ESPECIALLY on a laptop because its often moving places, placed down on desk etc.
Dezz do yourself a favour and make sure you get an SSD, heaps better than a normal HDD.
In terms of computer shops checked out scorptec? good service with decent prices.
your 1 year of rego starts on the day the rego expires, should you wish to rereg.
if you wait 2 months to re-reg, you'll have 10months of valid rego left, and still pay that 700ish.
This sounds a bit ridiculous. Having to pay registration for the months where it's unregistered = lolwut. Dat VicRoads cash grab.
when rego expires then you cannot drive car anymore.
if you pay it within 3 months then car rego again and all good.
after 3 months removed from system and you have to get full RWC and re-register the car
This is how I assumed it'll be. So if it's within 3 months, you DON'T need to grab an RWC, and just need to re-register the car? No extra fees? HOWEVER, then with regards to what Alvin said, you will be paying registration for 12 months starting from the ''initial" date it expired... as opposed to paying registration for 12 months starting from the date of re-registration ?
For example, lettuce say that registration expires 01 January 2015.
Scenario 1:
> Cannot drive vehicle as reg is expired
> As long as you "re-register" vehicle by 01 April 2015, you do not need RWC
> However, registration for "12 months" will only last until 01 January 2016
Scenario 2:
> Brand "new" registration required if registering vehicle AFTER 01 April 2015; RWC needed
> For argument's sake, say you do this registration on 02 April 2015
> Registration for "12 months" means this will be valid until 02 April 2016
These are the two possible alternatives?
Scenario 1:
Scenario 2:
senario 1
I've done it with the mustang now and then as it been off raod for 4 years.
Haven't looked at the links yet, but sometimes the CPUs can be slightly different models, screen size might be the same say 15" but different resolutions (higher resolution = better / clearer) and some may only have on board graphics, others might have an additional card. (nvidia or ati)
edit: checked your links quickly, aren't they all the R750JV-T4207H?
Edited by UNR33L
Ishan come to me when you've (stupidly) paid rego on a car that doesn't exist for 5 years just to avoid getting a RWC again...
Nah we took out one and gave it to you cause I was feeling charitable with my three hard drives. Then one of the ones we left in there carked it lol
All have the same CPU spec listed (Intel® Core™ i7-4700HQ Processor (6M Cache, up to 3.40 GHz) / Leap motion)
All screens and resolutions the same except the JB one being 15.6" vs 17.3" for the others... and all have the same Nvidia 4gb graphics card
senario 1
Interesting.
Haha wut. It's not that RWC is a huge deal, as-is should pass no problems at all as it did some months ago. Just the registration timing atm is not ideal for me - as if it were delayed say a month~ish, I can have dat dere concession reg pricing. But if there's fees such as just getting a RWC etc, gotta weigh up whether that time + money is worth the saving (not to mention the fact I couldn't drive it for x amount of time).
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
