ba first class lounge is where its at my man.
RAF brize norton departure lounge is not.
I've never been to one of these 'lounges' so I'll take your word for it.
ba has free incredible food, usually some sort of piano performer is evening, fre beverages alcholic and otherwise, a masseuse and that other fancy shit.
RAF brize, had a few buckets to piss in, stale ration packs and smelt of a 1000 soldiers balls.
I've only experienced BA lounge in heathrow Terminal 5...and was not impressed.
now Cathay in HK had a free noodle bar and asahi..that is awesome.
emirates standard pour champane in Dubai is Moet chandon, goes well with the hot dogs.
for some reason I still like Singapore the best however, laid back and good food. plus awesome shower cubicles.
ba had buisness lounge and the inside that was first class in calgary, was nice. also los Angeles.
yes cathy in hk is ace. i was more occupied by the cheap smokes out side tho.
only flown military flights to middle east.....
but yes, nothing in heathrow or gatwick is good.
That feeling is amazing.
until the bolt your mechanic left in your intake pipe destroys your $3000 HKS turbo and sends metal shards through your freshly built RB26....
that feeling is only amazing for everyone else
  • Like 1
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
