I probably wouldn't say they are worse, just more a popularity thing with Maccas
yeah it's how they eat here.
I got recommended to a resturant near hotel.
customer:
"yes around corner from your hotel there is a very good pizza restaurant, you may have heard of it it is called domino's. "
sigh
one of my other issues is they have lots of american chains.
one of the largest near hotel is TGIFridays.
sow, here Friday is not the last day of the week it is Thursday as they work sun-thurs
plus it's arabic so they don't believe in god.
so shouldn't it be renamed
TAIThursday?
So has anyone seen a massive increase of bats flying around at night? For the past few months ive noticed a huge increase of bats in the south eastern suburbs like dandenong and oakleigh.
Its pretty scary when you see a bunch of bats flying above your head.
always been bats around. mostly fruit bat population after fruit season, spreading out after starting in botanical gardens. been plenty in at kilda and seen plenty in Oakleigh last year or more
customer:
sigh
haha considering how well off of a country it seems to be you would think there would be better places to eat
Although never been there so could be wrong
lol'd
Also lol'd
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
