Martin what are your nuts made of?
If they're too soft (like cheap alloy ones) then they love to mangle themselves and fk up the thread of the stud.
I'd almost rather have a mangled stud than a mangled nut, since its easy to pop into a shop and pick up a single stud than it is to pick up a single MATCHING nut :P
Edit: Actually quite enjoyed changing a stud in the motel carpark at DECA, was a lot less painful than I thought it was going to be... Do S14's have little cutout areas behind the stud like 33s have, so you can bash it out and remove it without taking the whole assembly apart?
Only painful part was not having a hammer with me, so ended up using Anna and Luke's towbar :P Swung that shit like a baws...
yEAh the recheck is the trick...nip em up easy and recheck ...old man thought me years ago to do them up real tight, he would stand on the f**kers..so i would do this but I learnt over the years this was because he had a shit house wrench...add some decent leverage into the equation and they jus
Love JW black platts....especially at that price....not too fancy but not too shit either...its just right...specially with some dry ginger and ice...
I'm on the Bundy and coke zero tho tonight
In other news, Scotty ran right over my Nokia today in his whale..there was kumho tyres marks on it and all so i know it was him....
I had to defibrillatorize it a few times with my fist, but it Still works :D
yeah that said i did get a 25$ torque wrench form supercheap that does make a good wheel wrench...the fact it is a torque wrench is just a bonus
If something requires a torque wrench, I wouldn't be trusting a $25 one for the job.
+ 1 for using logic for everything else... I use a 60cm breaker bar, just a little tug on the end of it gets them to a good tightness, not overdoing it but def not coming off... Just keep those damn tyre shop rattle guns set to 10/10 away from my car and things will be alright...
Nokia tried to commit suicide, due to owner being a hack. :P
I can't believe it still works after being run over by 2ton of whale, twice. All hail the new Nokia brick.
Hey.
Anyone know anywhere where one can purchase something f**king mundane, possibly the most mundane of all Skyline bits.
A R34 N/A Series 1 Grey Front bar?
Bonus points for a rear bar and skirts, for a sedan.
Surely these must be lying in piles somewhere.
but where?
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
