Think it was like $150 for all four corners? Got it done at same time as all my poly bushes etc. so hard to tell. That was with Centreline too, so can prolly find cheaper at Traction Tyres?
I'm told it should be done anytime you make a height adjustment or major camber/toe change. Or lose/gain 20kg...
Nah, corner weighting is done pretty quick with the right equipment...it's basically a scales for a car placed at each corner and adjust the height of the coilover until the weight distribution is as even as possible. You never get 50/50 front to rear on a skyline but you can get pretty close side to side, which is what matters more.
My huge bill was from getting Centreline to replace every bush in the suspension with polyurethane, corner weight, install hicas lock bar and alignment/balance.
Probably not a bad bill considering, that's a fair whack of work and bushes are one of those jobs that are a pita without the right equip....
Does it involve ride height adjustments or mostly just dampner changes....Like if I had my car at a height I like would it come back a different height?
Even with the right equipment bushes are a flamin mongrel lol. I did it once on a car and never again. Centreline reckon they put 15 hours of labour into it...removing basically the whole undercarriage which is probably a legit estimate. Oh well, good thing about poly is you only have to do it once :)
It's ride height adjustment. You can tell them a certain height that you like it at and they can try to keep it, but in the end one of the sides will need to be raised or lowered relative to the other in order to redistribute weight...unless you nailed it straight up when you installed the coilovers lol. The reality is, that a car's weight isn't evenly distributed, so giving each coilover the same position and height at all four corners, although looks nice and even, will quite likely give you a shitty weight distribution.
50/50 weight distribution after corner weighting will likely have one side sitting slightly higher than the other. Usually the driver's side to account for your weight, but manufacturers sometimes build a car to be balanced with driver's weight included. Fair few variables to it.
Mine is crazy weird...i have about another inch tops that I can drop the front, the rear has about 3 nches more drop in it...that's with tyres sitting about 10mm from guards all around...so if I did them all even it would look very odd..
I did a couple turns more height on the right but nothing drastic...
So it's just height, they dont change dampening or tighten up your springs or anything...
Not that I'm aware of. How do you tighten up the springs?
Dampening shouldn't really affect weight distribution in terms of a static state, it will alter dynamics and ease of weight distribution / balance in a corner though. That may or may not have happened to me when I may or may not have put the fronts on hard and rear on soft at DECA...
A good suspension shop should be able to set you up with everything based on info you give them; track car, race at Sandown etc.
Just went to see Need for Speed with a mate, at Knox, in the Skyline...
Come out of Ozone and start walking towards my car, boom, highway patrol, boom, divvy van... Then in a random dark side street in Vermont (Mildara St for any Birds playing along at home) there were 3 marked cars just sitting there... some random domestic or something must have happened :/ But they were all standing around glaring at me as I cruised past, I honestly expected them to light up and follow :/
Good movie actually, it's a switch your brain off and enjoy the car porn movie :) And enjoy it we did :D So glad I saw it at the movies instead of downloading a dodgy screener version...
well the spring seats on mine are adjustable...I figure if you wound them up it would effectively change the preload on the spring...or sumtin :wacko:
Preload is how most coilovers are adjusted for height though...I wouldn't call that tightening, but you're technically correct if that's what you meant by it.
No..vehicle height is adjusted at the base of the coilover by winding the shock deeper Into the tube.....the base of the spring seat adjusts the preload on the spring...so if you want it stiffer spring you wind it up or "tighten" it...
Might be better in 3d but it's not fantastic...they are fast cars but just never really look like they are going fast....
I guess thats what happens when you dont use CGI
It is good entertainment though..quite alot of larfs early on actually
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
