optima = $4oo... but it will last a decade so.......
I had one in the 33 cos I needed to have it on it's side due to the 6x9's thing was totally worth it
I used to sit in my car on my break and watch a whole movie and then play some gamecube, battery was never flat
Just phone ordered some Indian food, took about 5 minutes for him to get my phone number right... Didn't think 'two' sounded anything like 'three', or 'thirteen' anything like 'seven'... Hopefully he got my address right or I'll be going hungry..
Who the f**k has a break long enough to watch a whole movie and play gamecube.....Anyway the whole notion is so last century..... most people just use ipads nowadays anyway...lol...battery just has to start the car...unless you like to sit in carpark with big stereo pumping for extended periods...
they have vegetarian rennet now.
yes... it's fairly widely available too... but it's still not in most cheese. (thank rajab)
well clearly not these days, but I used to run a kitchen where I had to be there on fri/sat/sun from 8am till midnight. On quiet rainy sundays i would go hang out in my car which was parked in our private courtyard just behind the kitchen for 2-3 hours. With a bowl of pasta, a couple of glasses of wine and the pillows/blanket I kept in there it made life a lot more bearable lol
OK so i'm selling the Evo... anyone want?
Gonna buy a $5k RB20 C33 as a train station car and club reg it... then use the rest for a deposit on a CX5 for the family.
Actually kinda looking forward to it as I have always wanted a Laurel and I HATE the golf
Swap the 34 for evo?
:P
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
