Should be a good car, like the other 3 cars I own at the moment. Will need to get rid of one at least once Barry gets it back on the road I think. Anyone want to buy an evo7 with brand new built 2.3 engine? :P
lol.
when I was there last it was buried in a sea of cars. are they just doing an engine for it?
you'd think there'd be enough evo engine parts floating around that there wouldnt be much delay.
I haven't driven mine yet, the 4 months don't kick in till the damn engine starts.
I'll offer you $62 and a welding rod.
OK so i'm selling the Evo... anyone want?
Gonna buy a $5k RB20 C33 as a train station car and club reg it... then use the rest for a deposit on a CX5 for the family.
Actually kinda looking forward to it as I have always wanted a Laurel and I HATE the golf
JZ cressida up the road for 1500$..89 model....tis auto tho...but get t56 and install for plenty good times.......
not to mention parts for these cars and parts are ridiculously plentiful and cheap
also I love that you hate the golf...even if you had to buy one to figure it out :D
was 2 tossers on westgate yeterday...P-platers racing, a golf and a sil80....I don't know who won but they were both lame
Wait wut? Hamish in a rb20?
Lol really have been accumulating the parts, all that's left to buy is wideband and tune really. Although true enough that's the better part of a K, sad times.
I soz wallet, I soz.
I'll wait for Scott to get bored of his lol.
I shotgunned that car first
There's an 8 with 2.3 E85 and 515kw or something ridiculous like that in the for sale section.
Dude wants 36k (?) though...
working from home today :D (sitting on my laptop at kitchen table since 8am and havent really done a lot though...)
Toby. do it.
http://www.skylinesaustralia.com/forums/topic/442046-vic-xd9-emotions-brand-new/#entry7263215
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
