Youre putting way too much effort in for a "budget job".
Guy isnt even going to notice the difference between the minor ones only you can see
its for my vanity :P
its just a really nice colour to work with...
btw i have a surprise for you...;)
Well yeah, I don't think he is gonna plumb it back for now (re: screamer).
How he is going to fit that into the 5in cat, I do not know. Unless he runs it direct to the body of the cat itself. I believe ARTZ had that done.
But my car cannot be made to 'look very sweet' by the efforts of one man alone.
It will most likely require the efforts of three men, namely scotty, artz, and aaron by the way of his guard roller and general "greg don't do stupid shit" advice.
is Scotty stealing my ideas again :whistling:
yes i run wastegate into side of cat....(well what looked like a cat)....2 pipe enter....1 pipe leave....works well..
i still haven't made it down to get your bumper either...as Lee said spending way too much time on red car....does look sexeh tho so its worth it...
hahah. im joking.
after the mani scotty had fuark all to do on mine. dump will take 1-2 hours.... cooler piping the same... i just need to get over and get the work done....
i literally worked for about 2 hours yesterday and didnt bug him once. i was proud.
hahah. im joking.
is that because he charges by the hour and you dont want to pay him for socializing
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
