I run ID's and if it's below 10 degrees my cars a bitch to start.
If the car has been on the trailer over night in winter and I try to start it at the track I have to wait for the temp to get up to about 10 before it will start.
It was tuned on a 35 degree day which probably didn't help.
Yeah on warm days, even anything above 15 degrees it starts first crank. Cold weather like today you can't even hear it fire a cylinder for the first couple of cranks.
  • Like 1
ive read a few articles mentioning the same amount.... maybe it could work.
id be taking it back to tuner and retuning in the cold tho....
Not a bad idea getting a winter touch up tune for it that I can switch to in the cold. Shouldn't cost too much.
yeah I didnt have any great issues either....Maybe its those crappy old Nismo injectors Birds ;)
I'd say it has more to do with the climate the car was tuned in and where you're starting it. My car gets left out on the street these days and inside the carport it does start much quicker. Pretty sure the bottom of my hill goes below sea level too, lol. Injector type or size should be pretty irrelevant; the timing and flow of them in the tune will matter more.
Besides, Nismo injectors are love...dat resale value through the roof. Just like my "outdated" PFC!
Need a tiny electric blanket around your fuel line birds.
Heh I was actually imagining doing something like this, but wrapping the whole engine. Also considered giving the fuel lines one of these
P.S. Medieval Lego ftmfw
Have a huge castle somewhere, so many trap doors and glow in the dark ghosts (actually just a regular Lego man in a ghost sleeve, but aren't they all!
  • Like 1
No, I prefer to get irrationally angry at people who get nostalgia about things that are 'silly new things that little kids are into'
Like Pokémon.
How dare this forum autocorrect and add that little thing above the E.
stupid nostalgic forum
well if your car is rwc...why worry?
sif be scared of tmu...just smile and nod politely as you do what they ask, then leave and do what the hell you want anyway
hmm only problem would be too low otherwise car is okay
always rely on much worse cars than yours to steal the spotlight. have seen bagged R32's scrape on modest carpark entrances infront of cops and they just watch to make sure no one does skids.
lol yeah this is true :P or i could just walk, market is pretty close. the melb car meets had a couple of people rev bashing and doing a skid on exit at the docklands one. :/
so you get told its too low...lift it...pass...then lower it again....
  • Like 1
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
