Is the CAMS license a 1 off fee? Or is it yearly?
Also, on another note. My car FINALLY got approved by the other persons insurer for repair. A whole month after the accident, QBE are hopeless. I should hopefully have it all repaired before the end of the month meet.
inb4 Birds is the new chef and cooks it well done
At home and with a stone grill, yes. But I've been having medium at restaurants lately. It usually comes out medium to well anyway, cause some don't have a clue about cooking different sizes and cuts or don't bother / have time to check it while cooking.
Plus hardly anyone at a restaurant knows how to cool a proper well done steak without burning it - they invariably whack the heat on high and burn the outside; jerk offs. It's supposed to be no red inside, without the burnt outside. Inb4 Hamish says they do this out of spite or to rush it out; some may do this and others are in fact clueless and glorified water burners.
next SAU BBQ we'll do a steak cook-out. I'll bring the Webber Q and its game-on.
Hamish vs Birds vs Alvin vs Ash.
first guy to die, loses.
PS. I clicked post before I saw yours Plattsy. so wasnt referring to you. gosh.
I have one thing to say to my fellow competitors
That is all
Will be there as part of the VWL Judging Panel.
yup thats right.
pay 75 bucks for a steak and tell some glorified water burner to cook it how he wants.
the words get f**ked spring to mind here.
because every piece of meat is different and as you cant see the meat in question, you can't ascertain how it needs to be cooked.
also because the chef at Rockpool has cooked probably 20,000+ steaks in his life and knows infinitely more than you about cooking steak.
which all of course means... you will get a better steak
how much would rockpool chef get paid? live off tips & compliments?
thats a lot of steak and boring/depressing lifestyle to be a maestro at a top shelf restaurant.
Honestly, a chef knows more about how you like your steak than you do.
Probably the most criminal rule broken of most food really. Customer preference means shit if the quality of the cuisine is good. You should learn to love everything :P
fark all + IF kitchen gets tips, it's usually 10% divided between the whole kitchen staff
yes, it is shit
apart from one thing.
how i like my steak.
this is of little consequence.
how can you say how you want a piece of meat cooked without seeing the piece of meat in question
easy. bring me a steak. make it rare.
simple. could be f**king 4 inch thick or half inch. i want it rare. simple as fark.
every other flamin mongrel in the world at top restaurants can do it. why is it so hard in australia.
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
