Vic Wasteland Thread
R31Nismoid
My cousin is after one, if the offer still stands I'll let him know..
What kinda damage are we talkin monica
18 years of general wear and tear + I think some of the mounting points may have gotten a bit mangled when it was hit.. I don't recall it seeming that bad, but I wasn't going to say no to a brand new front bar
Sounds alright, let me know if it's there for the taking
Also looking at club reg so non reg car should drop the price a little
remember club reg not for a daily.
ie if you going to drive it to the train station ever days, you will breach the regs on it.
speaking of illegal activity... yesterday's car meet at carribean gardens: so many p-players driving turbo cars. turbo civic, stock 2JZ supra, A45 AMG, VW R36.
not sure if borrowing parents cars or just not giving 2 ducks
and yay, got one week off because of bad back.
though i really wnat to quit my job and work somewhere else.
Bad back from what?
Time for some deadlifts with Birds to strengthen that back brah
  • Like 1
This is not correct anymore..
You can drive it for 90 days a year, as long as you have a logbook
Which pretty much means you fill out the logbook before you go, except the date field.
Get pulled over? Write date down quickly, and then you're good to go.
Mate with Club reg BMW has actually been asked exactly 0 times for his logbook the 4-5 times that's been pulled over/through a booze bus etc.
Bad back from what?
from sleeping wrong.
i reckon its just muscle imbalance or something. but you're right, i should start working out.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
    • So I checked this out in the weekend.. and look at this. I remember watching the videos. Finally got to see it in person! BRB. Tissues. Got tonnes of other pics and videos too.      IMG_0171.mov IMG_0113.mov
    • For anyone who might be put off by the slightly wacky wheel offset shown on the box photo above, the production models are not like that. Here's some more pics of the actual product (as well as the interior)
