I am a human calculator
I know this guy in Hallam who drives all these exy Mercedes
I'm surprised so many people I know get suckered into cheap car finance.
And I ask them, if car company is making a loss at by financing at below the RBA interest rate, where do you think they will make their money back from?
Residual value usually
driving through toorak & hawksburn reguarly when I lived in Burnley... would often see a lot of P-platers that were clearly 18th or 21st presents. saw a chick on red-p's once with the plates 18BDAY or something as gay as that on a 125i convertible. blaring something similar to Vanessa Carltons 1000 Miles. couldnt have gotten any more steretypical.
Any of you blokes who roll guards had to deal with lips that have been very very poorly smacked with a hammer? Unsure how to go about fixing it without pushing the outside of the panel about unevenly :/
You don't mess with club reg as it is your club and your friends that suffer if you get caught.
I will need it for approx 40 days for childcare pickups and 50 days if whatever I want (less 4 for attending club events) so that leaves me with a day a weekend legit driving (roughly)
You should be right; I imagine you'll be driving places the police have never heard of before
Ahhhh hipster jokes, they never get old...until someone else has heard them
So on topic of the FIFOs earning shitloads and throwing away their money, I met a couple on the weekend in WA
One asked me what I earn and then said he wasn't going to tell me what he earned, because I wouldn't want to know. I laughed and then he told me what he earned anyway, which was nice of him to do that. He bragged about taking home 12k in one month and pissing away 11k of it...which leaves him about on par with a 15 year old casual shelf stacker. Also expressed his concern about being able to pay back the remaining 15k of finance in his work ute...how the f**k? Then told me I should get into the mines. Thanks for the inspiration champ.
Pat I hope you are saving...
The best process is to stop being a bitch and just roll them
What do they usually spend it on?
Drugs & hookers? As there doesn't appear to be much to do in Perth
Have also heard that things are stupidly expensive up in mining towns... a $100 trolley of groceries can cost $150-200 in some towns up in queensland, purely because people have money from the mines... Pity about the "local" residents who can no longer afford to live in their own town anymore...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
