amazing nobody was up in arms when they got their free $900 bucks for nothin
I was, cause I saw this coming in a few years and knew we would pay for it. Meanwhile idiots screaming at the budget on their TVs that they bought with the $900...
Had a lot of fun prank calling people at the time, pretending to be from "the government" and asking how they wanted their stimulation package from Kevin Rudd delivered...telling them we usually just get you to bend over and take it.
eh power lifting not for me
spartans 365 a year too which is pretty awesome compared to the 695 bs genesis wanted on renewal I believe.
Powerlifting for everyone, most decent bodybuilders start off with it brah
Also I bet if you're going 4 times a week that extra 5-10 minutes of driving makes up more than the $330 in fuel a year!
Unless you run a corporation or trust. There's not much for him to keep in check
Your salary as an employee is what it is :P (inb4negativegearing)
Not an employee as such and mad deductions with my job which is more so where works out well still pay too much tax IMO
I got it... can't remember if I did anything special with it... Probably car parts and coke and hookers as normal.
Everyone bitches about Labor's spending, but I do believe that it was the spending which kept our economy alive and kicking through the dark years... I'm not saying all of the spending was logical, but neither are a lot of these extreme cuts...
It's easy to have a plan to do something by 2024, there's no promises to keep if you're not going to be in power for that long.
What part of labors spending was logical? Giving 900 to people for nothing including prisoners, dead people, people living oversease who wouldn't spend it in austrlalia? The insulation debacle? Perhaps school building except they got things built they didn't want or need..
I challenge someone to find the last federal labor government to return a surplus you'll truly be shocked with the answer
Almost everyone in Australia bought shit off eBay from China and the US lol
Labor would like to believe their spending saved the economy that may not have fallen into recession regardless (I fail to see the links beyond claims from MPs), but it begs the question, where did they get the surplus from to do this with...
after seeing the economy's in greece/spain/UK I see the logic in it.
basiclly there.
ppl here economic down turn, so decide to save some money rather than say buy a new car
so car sales places put some ppl off, unemployment went up.
ppl got more scared
started eating out less
so waiters/waitresses got put off
so on.
till it got to a point gov could not recover by just spending some money.
yes most of the surplus money went OS as hell we don;t build anything in AU.
but it kept ppl confident to keep buying things and the economy rolling along.
why else does every-one in the world envy AU economy.
and yes now we tighten up when in better times to pay that back and we still the lucky country
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
