I got them in a 255/40/R17
2 laps in and they were just spinning in every corner.
that's with 180kw at that!
I'm currently running at about 250-260rwkw with a nice smooth power curve so nothing really comes on too hard too fast, and the car does mostly street driving. I'm really happy with them because of their bang for buck ratio and their cold grip which is where I mostly use them. If I was taking it to the track then I wouldn't be using them, because as you say, they go off after a few hot laps and need to cool down.
They do smoke nicely at deca though ;)
Using the basketball court for a motorkhana circuit instead of the megamini, tyres do not like it very much...
Also, need rear camber arms :/
tried to claim me some centerlink yesterday.
apparently i earn to much or someshit, but every little helps. have to take the visa in and see what they say.
Im pretty sure Centrelink payments are exclusive to GTR owners only now
Sorry brah
nice nankangs bro...My cressy rolls on nankangs :P
My plan was... Nankangs on the 17's for pottering about, Stickies on the 18's for track grip...
Though it seems whenever it goes to DECA or Track the 18's go on, and then don't come back off for street driving because the BBS's look better than the AVS's.
*sigh* so it looks like I need to wait up to 4 weeks before my car is repaired again. The parts have been ordered from Nissan Australia and that's the estimate they gave to the repair shop.
Anyone ordered from Nissan Australia before? How long did it take?
Sounds about right.
Smaller parts will get here sooner.
What happened to the car? What parts take a month to acquire? Gotta be coming from JP at that timespan...
Was involved in a rear end collision. Rear bumper, 2 rear reverse lights, the back panel and a few others I think. Yep they are coming from Japan, I'm hoping it is more like 2 weeks delivery.
In the meantime spend your petrol money on alcohol, hookers, bet on black, buy crack, and moar alcohol
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
