Friday 4:15pm... For lunch I had Sangria Duck Ragu pizza and 3 glasses of champagne
Zero work shall be done this afternoon... Can't wait for Winton tomorrow... though just looked at Google Maps, gotta swing past Heathcote first, bloody nearly 4 hours one way. Blergh.
How much for a detail?
How far do you live from Frankston Hospital?
How many hours to do a black ute roughly?
just around the corner from hospital mate.....if its not too bad i should be able to knock it over in a day...but yeah depends how good you want it and how bad it is to start with...
im busy next week now it seems, but drop around one afternoon I'll have a look at it and we discuss...I'll pm you my address and stuffs :thumbsup:
pickup car monday afternoon woohooo
and my dell desktop had a wierd memory issue
random reboots, bluescreens and wierd random windows errors
reinstalled windows the same, spoke to dell, ran bios diags and it found "memory errors" and somehow marked a few memory addresses as "bad"
now its working sweet and it passes all the memory tests
i didnt know you could do that with normal DRAM
with ECC of course but didnt know the BIOS was able to mark certain blocks in memory as bad and skip them
Thanks for putting my phone number on the internet f**k face
You want some personal training, go do pullups with a length of rope, using your neck
jsut post his on an alternative dating site
or use it to book in some visits from mormons/scientologists
30% off Repco this weekend guys.
You'll need to be a VIP member though. It's free to sign up from here:
http://vip.repco.com.au/registration/register/1141
Once you sign up you'll be sent a temporary card in your e-mail. Just print it out and take it to the store.
very nice, might get myself a new jack this weekend then.
damn. pizza sounds good?
you coming tomorrow? hope Miguel is gonna make it worth your while :P
made it to be malls in one piece. got 10m through Clayton back streets before I had to break up a domestic dispute involving police to ask whoever the owner was to move their torago at least 1m closer to the curb as trailer wasn't going to fit #easternburbs
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
