hmmm shannons charging $700 for laid-up cover while car is not on the road... not sure if value or not. either way, still cheaper than the regular full-comp.
My full comp is less than that
despite passing that place almost daily, i've yet to try. pretty sure my dad goes there from time to time says it's okay tho.
The meats are hit and miss, sometimes great sometimes shit.
You go there for their roti, which is always perfection and good value.
Khazana at Knox O-Zone do a good Indian feed. Banquet is all you can eat mains and it's much better quality than Rich.
Aka third party, for which $700 is a joke rip off.
chicken 65 isn't hot
I'd probably say spice tolerance levels is a personal thing.
The level of spice may not be beyond your tolerances but could be for others.
Jeez Hamish get it together man
  • Like 1
Cause your car isnt worth $700 :P
Its covered for its full value if stolen, damaged whilst in garage or in transit. So not quite 3rd party.
There's more to it than tolerances too. I'd refer to a large range of atypically spicy foods as being hot, despite me being able to tolerate bhut jolokia ingredients.
So to me it's like saying a car isn't fast. You could say the new GTR is fast...then some wanker who drag races professionally could say it's not, just to try and make himself feel superior to everyone else. But the car is still fast, because it's faster than a hell of a lot of cars and most people would say it's fast.
Similarly, chicken 65 has a solid kick to it and the writing chalked on the window by the chef says says hot, too...so it's hot.
Hatish
Hatish
so your calling hamish a wanker...... basically.
Is your car worth more than 10k? And by that I mean, are you currently insured for more than that, that they would pay out to you?
Agreed value is $16k or something i think.
My understanding is that its the same as comprehensive, but not covered if in an accident when driving on the road.
Yeah its only handy if you're going away on holidays/overseas for ages, or the car is not running and won't be on the road. You'll still be covered if it gets pulled out of the garage and stolen while you're away.
Fair enough then. Cause my third party theft is about $300 on Skyline and that covers theft for $10k, which is fine for a 33.
Used to be full comp but didn't see the point to $800 full comp on a car worth 10k and especially not when the full comp excess is higher than the third party excess. One year of third party and I've already saved an excess worth of dollars or money to repair some shit happening to my car.
it originally came at the time of Mahendravaram I, a Pallava King who defeated the Kalabhras. Mahendravaram I is seen as a hero by many in the Tamil Nadu district and legend has it he himself slaughtered 65 enemy soldiers and upon victory ordered a grand feast. His personal chefs took the remains of the 65 slaughtered and cooked them such a way that all were awed at the fantastic taste of human flesh. Since then the main ingredient has changed to chicken following the demise of cannibalism, yet the precise spices and cooking method remains the same. Chefs decided the name the dish Chicken 65, as the original dish contained 65 corpses.
Now hungry for enemy soldiers
Enemy soldier night @ Alvin's this sat
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
