If I wanted a track or drift car that would be a good start. Body's not in bad nick, though. It's what these idiot P platers should be buying and storing instead of spending 10k on an N/A version of that.
almost a week untill the piece of shit gets tuned.
aw yes
scotty, hows cihan as a tuner?
heard all the good stuff lol
nice.
do recommend. gave positive feedback and seems to know his stuff. struggled big time to book him in. he just chose to not rock-up a couple of times...
however, we'll see what sort of damage there is in my engine first...
aw yes
He knows his stuff, but it's a hobby for him these days, and his work comes first. It can make him difficult to contact.
nice.
What fuel were you running?
Can you prove that a lack of E85 wasn't the reason?
yeah because springs broke, causing rockers to scratch, causing cam lobes to be damaged.
all the while bottom-end bearing fails, rod comes loose, whacks the block and scratches piston an cylinder walls.
would E85 prevented that and engine would still be running 100%? I think not.
would the tuning required for E85 continually melt my external ignition coil? possibly.
would the extra power/torque cause enough power/torque to destroy my headset? possibly.
would the 50L fuel tank need constant jerry cans on standby? probably.
    • Hmm. I should have thought of the clutch bleeding issue. It should be #1 thought for "can't select gears". As to "sounds like the top".....have you actually gone out with the stethoscope and tried to pin it down any more than that? And, buy or borrow a timing light, and set the timing properly.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
