Interesting deposits Dave...did you drain the fuel rail and injectors before you cling wrapped them?
Probably is sugar...
well obviously not :P 4 months it took to get like that...maybe condensation was building up inside cling wrap...not sure... need to do some testing...I have 10lt od e85 here maybe i should put it in random things and let it sit....see what corrodes ;)
Ah well of course it's gonna leave some shit in there then...would dissolve the moment you run more ethanol through it. Though on first start it may make the ethanol a bit crap. That is one reason we say to leave petrol in there to "pickle" the system if you're leaving your car dormant for extended periods of time. But I don't imagine that sugar shit causing any harm anyway.
Quick recommendation on new headlight globes since mine blew last night.
Thinking either OSRAM or Philips Xtreme-vision, but open to suggestions...
I've used Philips and Narva?, much of a muchness i think
Im not too shabby a solderer but circuit boards are so much easier than free hand. Struggletown even doing RS232 with jaycar kits. Smell of cooking skin is stronger than solder
Come solder my lights
I put the xtreme vision in the missus Mazda3.
tested it with a lux meter I downloaded on the phone and saw about a 40% higher lux reading in the same exnvironment.
very noticeable difference when driving in the country as well.
BUT I've run the same in the ute and they do blow more often,
as the saying goes, those the burn twice as bright burn half as long.
  • Like 1
Narva plus 120 or Intense if you like white/blue light
But I'm not biased or anything...
Can supply soldering iron and lead-free solder.
cant say id do a very clean/tidy/good job, but will work.
If your bored on the weekend come around!
Otherwise was going to buy a solder on the weekend and fix my front indicator light, as the wiring as torn off
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
