deposits wont be sugar.
They are very likely a residue from soluble organic junk in your tank. Kept petrol for awhile? Some gunk settles at the bottom, i expect its the same for e85, except e85 dissolves that shit, and drops them when it evaporates completely.
If your bored on the weekend come around!
Otherwise was going to buy a solder on the weekend and fix my front indicator light, as the wiring as torn off
I'm working Saturday, but free that evening or Sunday morning?
I tried these first:
Narva plus 120
but only lasted about 3 months, moved to phillips, getting at least a year out of these.
No good. Didn't touch the bulb glass during installation, did you? Should have written them an email...they generally send out replacements when that happens in such a short time.
Obviously performance globes differ in life to standard globes but should be getting more than 3 months out of them.
hmmm I'll have get a stand... maybe a sponge would be good too for cleaning the tip (that's what she didn't say, cause she likes it dirty)
also should have lobster roll this weekend. good shit
nah use rubber gloves when handling them to be sure.
didn't want them again if die quick as you have to dismantel parts of the engine bay to replace, (either the whole airbox or the battery and cradle)
so changed up to phillips.
hey if i plod around in 2nd gear and low speed the car is quiet jerky
not beef jerky, but kinda engine revving jerky, almost makes me look like i cant drive
is that the mega cams doing that?? is it something i can tune out with more or less ign timing?
only happens on light cruise in 2nd gear at low speed, if i open the throttle it goes away
My car does this. Wasnt sure if cams or just setup. 3 different tuners and still does it, so not sure if tune will help
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
