I would imagine it is also part of a stewardess' - that's fkn right I said stewardess' - job to ensure people are not overly intoxicated. This would be pretty much more difficult with a bunch of bogans trying to take advantage of free piss and out drink each other.
  • Like 1
just rock up to some random import workshops. I rocked up to springy motors randomly (never been there before) and they had a Z32 afm plug laying around that i could have. job done.
any r31 skyline at the wreckers has a z32 plug....why people pay 50$ for tomei plugs is laughable
its for my car (evo 8) so need an evo plug, or mitsubishi equivalent
will see what deer park wreckers have in stock during the week (not open weekends)
sorry cannot help...only asked cause i think i has r33 plug around somewhere
pwah do want.
http://www.my105.com/ListingDetails/tabid/65/p/3/cid/613/id/11466/Default.aspx
would be awesome to rock that on the road.
Brisby has a cossy that he brought over from europe while he was there, looks heaps better than that one though
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
