See my Sister and husband are FIFO.
hyundai I30 and a stock Golf GTI
last holidays were Bora Bora and Japan...
prob drink less than any-one else in my family
so they not all like that.
We're working with the 80% figure here...Patrick is in the 20%...for now :ninja:
  • Like 1
Have+some+cream+_33b32b25e3e579547829796
I actually have met plenty of tradies in my time (as have most people) and as al said, this would be 80% of them.
I also have a couple of mates that work FIFO in the W.A. mines and guess what...
They are both 101% Strayan
They both drive heavily modified V8 utes
They only holiday in Thailand/Bali where they only eat white people food, get full sleeve tatts and absorb 0% culture.
They rock cheap shit +11ty offset rims
They only drink Australian beer.
They listen to nothing but JJJ all day every day
They watch every sporting event known to man
AND
They get wasted on EVERY... SINGLE... FLIGHT...
This fits most of the FIFOs I've met here in WA to a tee. Groovin The Moo festival was full of them, which is basically a JJJ festival.
So accurate, in fact, that you should consider a career in marketing; a profession that encourages stereotyping. Bloody marketers, stereotyping pigs, all of them!
  • Like 1
Girl I know doing life drawing for her hen's tonight... you working?
does the CT9 plug need to be wired in or is their a connector at both ends? If it just plugs in you are welcome to borrow mine for a day.
Also doesn't Scotty have an EVO that he isn't wen driving right now?
found a pink 2004 CS lancer at pick a part
and hey presto, same plug
the plug is part of the main harness - wired in the DSS box and the engine management system, who ever wired these things in will know if you have your seal belt undone
yeah so all good
v happy now
just need to "fit it" so that its in the engine bay
What I think hamish is trying to say is.
80% of fifo's are the stereo type he states.
and 100% of those fifos in his 80% barrier are tradies.
other 20% who dont fall into the stereotype, engineers :P
So, All fifo tradies are what hatish states.
Muahahahahaha
  • Like 1
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
