GTX3076
2.8 (comp is supposedly 8.2) - Stock exhaust manifold, stock airbox, 3in exhaust, automatic transmission (the slip up top was 8% through it), return flow cooler, etc.
As for how it occurred.. it really did occur at about 30kmh, driving in 4th gear (which is 5th for you manual people) minding my own business turning right, UNDER the 'advisory' speed for that corner.
I had 30 eggs in the passenger seat. None of them cracked. I hope this leads Mr Shannons Assessor to believe me when I say I wasn't driving like a tool in the rain and it was a low speed impact.
See photos I linked a few posts above with the imgur link
Or I'll just post it again -> http://imgur.com/a/2JKpW
Pretty much had a direct impact on both passenger side wheels - whatever holds them straight (i.e, rods of which I do not know/cannot define/of unknown origin) are clearly snapped or bent. Or I just got a free wheel alignment of about 30 degrees of toe at the rear, and a front passenger wheel which decides it doesn't have time to listen to the steering rack anymore.
There's a good fist/sized (in volume) dent in the front bumper too, right under the front indicator on the passenger side. I didn't take a photo of that cause I dunno, I was busy being rained on, and such.
it was right here -> https://goo.gl/maps/r4XxQ
There's a farm here -> https://goo.gl/maps/SAsmh that claims to sell the best eggs in the world. They're really good. What better thing to randomly do on a sunday than taking a nice relaxed drive through the hills to buy eggs, to just enjoy the fact your car is finally working, because it's far too wet to do any 'spirited' driving?
People saw the dyno sheet and asked me what its like to drive... I don't even know.
I'm just going to cry myself to sleep now.
Dude that sucks!
On another topic
Don't ever go to burwood hwy tepanyake. Had to go for a bday and now I'm f**ked with food poisoning.
Fkn disgraceful cooks were using the spatulas to turn the lights on/off and and used the same cloth the waitresses used to clean the tables and chairs to oil the stove
They don't even know how to fkn cook. f**king pissed me off more when you here some dumb f**k go oh he's a good chef.
/rant
Dude that sucks!
On another topic
/rant
looool sucks to be you....
especially today!
Inb4 Pat launches into tirade about 80% of chefs meeting this stereotype
that's fair, 80% of cooks/chef absolutely suck anus.
I worked f**king hard not to be in that 80% so stereotype away! ;)
  • Like 1
GTX3076
Sad to hear about the accident!
But that is an awesome dyno graph!
Got specs on the Engine build?
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
